beazleybub's avatar
beazleybub
Water damage and restoring my Forest River Sandpiper
My wife and I plan on living as full time fivers within the next two years and recently bought a 2002 Forest River Sandpiper 26' fifth wheel. We bought it knowing that it has water damage and believe it can be repaired. I have decided to replace all of the exterior plywood because the water damage was fairly heavy to the nose and rear. Some of the roof is sagging on either end of the rig along with the celling. I'm positive I'll be replacing some roof trusses because of it.
My question is, do I repair the exterior plywood and framing first or, do I repair the roof first? I'll be doing the repairs outside and will be covering the rig with tarps to keep it from getting rained on.
My first thought was to separate the roof membrane from the filon sides and leave the roof and membrane intact and repair the walls first. Does this make sense? Replacing all of the exterior plywood will give me a good view of the studs and allow me to replace what's rotted. After the plywood goes back on, I will be gluing new filon on.
Thanks!
