kemer's avatar
kemer
water heater ??
On my 2002 Montana 2955RL, the panel for the switches to operate the water heater and water pump has a little light in between the switches. Once in awhile, the light comes on. Just wondering what the significance of that is. I rarely use the water pump so am assuming it has to do with the water heater. Anything to be concerned about? THANKS.........
  • On mine it indicates the the propane burner on the water heater has attempted to light 3 times without success. It won't attempt again until the switch is reset.
  • That little LED light comes on while the propane water heater is trying to light. It goes out as soon as the burner is ignited. If it stays on it indicates the burner failed to light.
