Good Morning, I have a 2012 Montana Mountaineer 29 footer. My problem is the water heater. Four time in one year, the electric part has stopped working. It has been the heating element and the therm...
Common problems with elements are build up on the element form lack of draining/flushing tank, turning element on without water in tank and loose/bad wiring at terminals on element.
Common problems with t-stats are loose/bad connections on terminals and lack of proper tank wall contact.
What Brand/model? What do you mean 'gets too hot'? How many elements have you had to replace? How many t-stats have you had to replace?
