Good Morning, I have a 2012 Montana Mountaineer 29 footer. My problem is the water heater. Four time in one year, the electric part has stopped working. It has been the heating element and the therm...
4 electric elements...then there is a problem with miswiring or high voltage condition
2 t-stats......either the wrong ones were installed (12V DC vs 120V AC). Your Suburban WH uses two different sets of t-stats ie: 120V AC set for electric element and a 12V DC set for the propane. OR Improper installation......not tight against a clean area on tank wall, forcing the connections on bending terminals which loosen them up or high voltage conditions
