portliz's avatar
portliz
Water Heater Bypass
Prime Time Crusader 290RLT. We are de-winterizing and can't locate the water heater by pass to let water into the water heater. WE are heading for Florida and are stuck in Shepherdsville KY. Wind gusts to 40 mph. Not worth taking the chance on the road BUT I would love some hot water. Thanks for any help.
  • Thanks everyone. Found the right ones. GAWD I love this forum. Wait a few minutes and 2 replies.
  • If you have 'water panel' check position of 'winterize' switch/valve
    If no wet bay then check backside of water heater for valving
    Depending on which set up you have....1 valve, 2 valve or 3 valve
    Cold water goes in bottom of WH
    Bypass connects cold & hot water lines
    Hot outlet comes out top of WH
    Cold inlet-----OPEN
    Bypass---------CLOSE
    HOT outlet-----OPEN
    Cold can be single valve, bypass single valve, hot single valve (3 valve)
    Cold can be single, bypass single, hot no valve (check valve in out)---(2 valve)
    Cold/bypass can be 3-way valve, hot/bypass a 3-way (2 valve)
    Cold/bypass can be 3-way, hot out no valve (check valve in out)---(1 valve)
  • if you open the storage door there should be a access panal to access the back or if you have the conviance station there should be a valve that is marked norm. winterize
