BB_TX wrote:
Are you comfortable troubleshooting 120 vac? And do you have a volt meter? If so, page 9 of the Suburban WH manual shows the circuit for the 120 vac portion of the wiring.
Could be the switch inside if you have an inside switch, the switch on the water heater outside, the high limit cutout/thermostat, the element, or bad place in the wiring anywhere in the whole circuit.
If you have another brand, a google search should find that one also.
Yep it a Suburban, and I have a neighbor with a volt meter who said he would check it out. thanks for the suggestions, didn't know about the high limit cutout/thermostat. We have used this 5th wheel a lot and this is the first time for a problem with the water heater. Trailer is a 2013. thanks again.
