TruckinRazor
Oct 19, 2013Explorer
Strabo wrote:
Make sure propane is on also unless your using electric to make hot water, in that case you dont use the propane switch on the wall.
How do you have it setup, propane or electric?
To better explain, I just switched from a Jayco to this Eclipse and everything is completely different. On the Jayco both propane and electric switches for the water heater we nect to each other and you could choose. This Eclipse has one switch and I'm assuming it switches itself to whatever is available? If no electric is detected then it uses propane? Does this sound right or is the propane switch somewhere else?
About Fifth Wheel Group
