TruckinRazor
Oct 20, 2013Explorer
Old-Biscuit wrote:
No..not like fridge
Water heaters have separate switches..no 'auto' select
One ON/OFF switch for electric element
One ON/OFF switch for propane
With only one switch inside I suspect you have a Suburban Brand and the electric ON/OFF switch is located in the outside compartment
That has to be it then, the propane was turned off after the first day and if the switch is outside then we never turned it on.
Thanks I will check that when I get home.
About Fifth Wheel Group
