Arch_Stanton
Oct 20, 2013Explorer
I have a new Eclipse Attitude 32AKLG and unless you upgraded the water heater I believe the standard unit is propane only, no electric element. Our heater is an Atwood. Ours is propane only. I always make dang sure the water tank is full before firing up the burner. Takes about 15 for it to heat up nicely.
Also, my propane-only unit came with a plastic drain plug, no sacrificial anode attached to the plug.
I changed that out right away.
About Fifth Wheel Group
