Arch_Stanton
Oct 21, 2013Explorer
You do not need an anode rod for an Atwood....that's why there wasn't one. The tank is an aluminum alloy and that's why it has a nylon drain plug. Putting an anode rod in is a waste of money and the steel treads on anode rod can gall up/seize in the aluminum threads of tank.
Check Atwood website.......NO anode rod.
Just because an item is available via aftermarket doesn't mean it is needed, better or an improvement.
Thanks, O/B.
The last Water Heater I had in my other RV was an Atwood, it had an Anode and was also aluminum. Came that way new. I will pay attention to the threads, been playing with these things for around 30 years and have managed to avoid wiping out the threads so far, but I have a set of NPT thread chasers if something should go wrong.
Aqualholic that is a weird one, indeed.
Your water heater has an electronic ignition it fires a spark like a spark plug to get the propane lit. Somehow, you've got a problem between the two 12v circuits. I'd start looking at the ground of the stereo.
Thanks, O/B.
About Fifth Wheel Group
