fpresto
Nov 16, 2014Explorer
Cool Canuck wrote:
It is normal for it to drip. Change it if you want, but I can assure you the new one will drip as well.
I don't know where you got this idea. Does your home water heater drip? It is exactly the same valve. A properly working valve can only leak if the pressure and/or temperature is too high. The OP's issue is either temperature or pressure or most likely deposits built up on the valve seat.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
