slarsen's avatar
slarsen
Water heater question
I have a 2010 5th wheel, made by Keystone.
I turned off the water heater switch earlier this year because I drained the tank and didn't want to burn out the electric heater. I assumed the same switch would turn off any possibility of the gas heater, too, but on my way back from the Gulf, I walked by the trailer at some point and discovered the gas heat was running. On an empty tank.
Maybe that has happened before and I didn't notice it. I pulled a wire loose and that stopped it instantly. I recently de-winterized it and did a shakedown local camping trip; hooked up the wire and turned the switch back on. The heater worked fine on electricity.
SO . . . the question: should the gas heater work when the switch is turned off? Any thought about what is wrong, if anything?
(I should note that the sheet metal around the water heater was replaced last fall, following a tire blow-up, so the heater may have been removed during replacement.)
  • Most trailers that I have seen also have a "switch" for the gas operation of the water heater. If the switch is "off", the water heater will not light and burn regardless of whether there is water in it or not. Only when the switch is "on" with the gas ignite and burn to heat water. Does yours not have a switch for gas as well as electric?
