- Old-BiscuitExplorer III
- pyoung47ExplorerOnce tripped, they will often leak a bit. My trailer is an outdoor dog, so it’s not a big deal. If you are anal, replace it — and in due time, it too will dribble.
- cummins2014Explorer
ford truck guy wrote:
I have found over the years that IF they start leaking there usually are 2 ways to go ( in my eyes)
1- open and close the valve a few times, sometimes a small piece of debris will be stuck there allowing for a leak..
2- more likely you will have to replace the valve, which is quick, easy and painless.
That’s the first thing I did, open and close. Mine had just got bad would not seal . Yes it’s easy and inexpensive to replace . I didn’t mess with mine much , just replaced it . - "We think too much alike!"
for the most part... Who knows, perhaps your my long lost brother from the other coast ! :-) - Cummins12V98Explorer III"1- open and close the valve a few times, sometimes a small piece of debris will be stuck there allowing for a leak."
We think too much alike! - alboyExplorerOUR suburban was doing the drip from the relief valve , did a complte flush ,no help, changed the thermostat , fifteen minute job , no more issues
- EsacnjExplorerThanks to all. I will try to re establish air pocket.
- wildtoadExplorer III had the same problem with my Suburban WH and no procedure worked to fix it. There is nothing wrong with your valve most likely, it is a design issue with the water heater IMO. Suburban knows it’s a problem, says so in their manual, and has no plans to correct this feature. I struggled with this issue for four years and finally took Suburbans work around their problem solution.The only solution is to install a small pressure tank inline with the water heater. The pressure created by the heating of the water is absorbed by the tank and not blown out the relief valve.
I never had this pressure relief issue with an Atwood in five other motorhomes. - I have found over the years that IF they start leaking there usually are 2 ways to go ( in my eyes)
2- more likely you will have to replace the valve, which is quick, easy and painless. - cummins2014ExplorerOP , there you go , plenty of answers , but yes they do get bad . Mine started dripping , replaced it , and no more dripping . As far as the air pocket and all that , never had those issues or had to do all that draining and whatever . All that has been mentioned could happen it sounds like . I just replaced it .
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
