bob213
Mar 03, 2020Explorer
Lynnmor is correct about air pocket. Atwood seem to have this problem more than Suburban. No need to drain entire tank.
try this:
1. Turn off the water heater.
2. Turn off the cold water supply line.
3. Open a faucet in the RV.
4. Pull out the handle of the pressure relief (P&T) valve and allow water to flow from the valve until it stops.
5. Release the handle on the P&T valve - it should snap closed.
6. Close the faucet and turn on the cold water supply. As the tank fills, the air pocket will develop. Repeat this procedure as often as needed to reduce the frequency of the weeping P&T valve.
try this:
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
