Anode rod has NOTHING to do with heating on electric and/or propane.
It is a 'sacrificial' used to protect the glass-lined STEEL tank Suburban uses.
Electric heating element is under the cover next to drain plug.
AC power comes from your AC Panel via a circuit breaker.
AC Power goes thru On/Off switch (lower left corner in outside compartment-----may also have another On/Off electric switch inside if RV Mfg. added one)
From switch power goes to the set of AC thermostats (under cover above gas valve with 'push to reset' left one /right for propane)
Then from t-stats (High/normal) to element
If your Circuit breaker has not tripped and On/Off switch is ON......Push the Reset------if you feel it reset then it will heat until t-stat trips again.
That means 'normal' t-stat is not opening when it should and High temp is tripping to stop from over heating the water. New set of AC T-stats
If high t-stat is NOT needing resetting then electric element wiring could be loose or element bad. Tighten terminals screws if wiring loose. Bad element replace it.
Also check the wires on set of t-stats.....sometimes the rolled lip were cut out is for t-stats will cut insulation on wire...shorting it
