Dukecity426
Mar 18, 2019Explorer
Water hose
Can anyone recommend a water hose that stays flexible during cooler temps. Right now I have the Camco water hose and when the temps get around 40 degrees or so, it is simply annoying to try to roll th...
ependydad wrote:ford truck guy wrote:
I already have the Watts saved into my cart on their site, just was not sure about the hoses...
My Watts that I use now has an issue with the screen, I forgot to remove it for the winter and it froze ... darn me...
Check with RV Water Filter Store, they might be able to replace just the gauge. I had to do that a few years ago. In fact, I could probably do it again- mine is showing way low (like 20psi) when I know the pressure is higher. If I recall, it was something like $20-25.
