lamopar
Dec 29, 2017Explorer
It is not condensation. I looked this morning as it rained and the water is running through the U shape seal at the bottom of the window channel that the window slides down into when closed. I have water on the floor below the window. The weep holes are open and we verified that by running a small flex tie through all of them. It appears the water is running past the outside seal on the window and filling the void then coming up on the inside of the window. I thought the water that gets past the outside seal would end up going out the seep holes but that does not seem to be the case.
I now wonder if the seals are just dried out and allowing water to pass through. I did find the same thing starting the other side of the trailer. That window is not normally in any sun when sitting.
We are not living in the toy hauler and do have a dehumidifier running in the unit when we end a trip to remove excess humidity.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
