golf_bears
Dec 11, 2018Explorer
I went through the same problem as you. It may be the water pump check valve but I doubt it very much. The KantLeak water valve assembly is notorious for leaking. I chased the leak problem for some time. I finally added a shut off/on water valve on the water tank line. When on park water I shut the valve off, when on tank and pump water I open the valve. I was going to put a check valve in on the input line to the pump but found it easier to put the on/off valve on the water line.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
