asherdasher63 wrote:
No we don't have one. And the park here has pretty hard pressure. I just have the outside faucet on real low but its still high.
Just because you don't have the valve open all the way, doesn't mean that the pressure won't equalize in the whole system; it just cuts down on the volume. Run to Wallyworld and get an in-line regulator before you blow something badly. Even a cheap one is better than nothing.
Try running on the pump and see if the leak stops. Keep running on the pump if so.
Lyle
