amdriven2liv's avatar
amdriven2liv
Water line noise/ air?
2010 Mountaineer 324RLQ
Just recently, there is a noise in the hot water line near the hot water tank. Sounds like maybe air in the line.
I have released the air in the tank. Turned off water supply, released pressure in the lines, released the hot water tank pressure valve. Still have it.
Any thoughts?
  • You might try emptying the tank and then refilling. Are you hooked up to city water or well water? If well water, after you empty the tank put some bleach into the tank and let sit for a few hours, drain, refill and drain one more time to flush out the tank. I don't know if this will help but worth a try.
