Crdodd
May 28, 2013Explorer
Water pouring out at fresh tank
I just returned from a trip and was surprised to see water pouring from underneath the rear of my trailer. It was a 90 mile, 2 hour trip. Amazingly, the water started pouring out just as I got home, as in lining up to park it.
It is in the rear near the fresh tank. The other tanks are much further forward. I think I have a low point drain and an overflow tube. I just figured that the cap came off and the water was draining out of the low point drain. It seemed to be fresh water, and I sure did not have that much in my other tanks. So, I tried to replicate it. I put more fresh water into the tank, but it did not flow through. There does not appear to be any stop on what I believe is the low point drain.
Any thoughts on this? Why would water be coming out of this drain sometimes. It could have happened before, but i just happened to see it only this time. The weather was warm, but not near temps that would cause a pressurizing effect. And if it is the fresh drain, why did the water I added afterwards not flow through?
Thanks for the replies.
