First of all the faucet on my kitchen sink is a single handle unit with a removable spray unit attached to a flexible metal rapped type hose from which both hot and cold water are discharged. Not sure about the correct terminology. The restrictors I removed were in the flexible hose and also in the spray unit. I removed the spay unit from the hose and was able to remove the restrictor with a cork screw. I then used my air compressor to blow the restrictors out of the flexible hose. Reassembled everything and I now have plenty of water coming out of the faucet. Was an easy fix after I figured out what the problem was. If I knew how to post pictures I would but I was never able to do so in this forum. If you want pictures let me know through a PM with your e-mail address and I’ll see what I can do.
