Rimrocksgismo's avatar
Apr 04, 2014
water pressure
I have water pressure to shower toilet and bath sink but very little to the kitchen sink. replaced water pump with one I had on hand because the other pump did not want to pressure the tank. hooked up to city water direct to see still not much better any thoughts?
  • Unscrew the end of the faucet end and clean the screen. They continuously get plugged up with gunk.
  • On my trailer there are two possibilities.
    1.. There is a cartridge filter under the sink that can clog up. This, however, is only on the cold side.
    2.. There is a screen in the end of the faucet spout that collects sand and gravel. You should be able to see a locking ring on the spout.
    If it is cold only that is reduced, #1 is most likely (or a cutoff valve has been partially closed somewhere in the basement).
    If both hot and cold are reduced (what mine did) then #2.
  • Subscribed, what make of trailer do you have? I have the same issue with my 2013 Big Country, good pressure in the bathroom, but weak @ the kitchen, both hot & cold. Maybe someone has a answer for this problem.
