balesfam's avatar
balesfam
water pump check valve
I have a bad check valve in my water pump. When hooked up to city water my fresh water tank fills over night. I know for sure because I have a by- pass valve I use for pumping antifreeze into the system for winterizing, and water will seep through when it is closed, meaning, closed from sucking from the fresh water tank and sucking from the antifreeze jug. My Question is, can I use this by-pass valve as a check valve to keep water from filling fresh water tank. The by-pass valve is between the tank and the pump.
