- bluckExplorer
Old-Biscuit wrote:
Would that be the panel (left side)........sorta slanted?
Never saw such a clean and empty basement except at a dealer. - lakeside013104ExplorerThat is the one. Nice picture Mr. Biscuit.
Lakeside - Old-BiscuitExplorer IIIWould that be the panel (left side)........sorta slanted?
- lakeside013104ExplorerMy pump is directly behind panel in basement closest to dump valves/water intake valves. Four #2 phillips screws and you have access. Good luck.
Lakeside - JW_of_Opechee_SExplorerIn our Jayco 35CLQS it was behind the storage area panel right where all the water control valves are. You need to remove a few screws (Usually square drive) I replaced mine and it was really easy once you get the panel out of the way. Don't have pictures for you because I now have a Cameo which I like even better.
- BurbManExplorer IIIDon't know your specific model, but they are usually in a cabinet or storage area (like under the dinette) at floor level. They are always left accessible so it's not like it's behind some secret panel. Under the kitchen sink is a common mounting place. *Generally* they won't be located in slide-outs or in the upper level of a 5er.
Or call call Jayco Customer Service at 800-283-8267 with your model # and serial #.
As an aside, how do you winterize the unit if you don't know where the water pump is?
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
