DutchmenSport
Nov 05, 2017Explorer
If you are connected to city water, your on-board pump should never need to run.
I'm assuming you are talking about running your on-board pump and water in your fresh water holding tank... yes?
If so, you have air in the line somewhere. Mine does this sometimes, especially after draining the water heater and tanks when returning home from a trip and then filling everything up again for the next trip and pressurizing the water system again.
I have found the shower line is my biggest culprit when this happens. Easy fix is to simply turn the water on at the shower and let it finish spitting air.
One more thing that can act like an accumulator tank is your water heater. If you have recently drained your water heater, when you fill it again, there is an air pocket at the top of the tank. This air can make the system act like an accumulator tank.
Still, it's not uncommon for the pump the run another couple seconds after turning off the faucets. Now, if the pump continues to run for 30 seconds, then you've got some serious air in the line somewhere, or else your pump needs to have the high and low pressure on-and-off re-adjusted.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 11, 2026
