ShipperExplorerSep 01, 2019Water tank location on Minnie plus 25 RKS?Buying a new Winnebago Minnie Plus 25 RKS and concerned about the low pin weight which is only 11-12% of total dry weight. If the water tank (50 gal) is in front of the axles, I can shift some weight ...Show More
buckyExplorer IISep 03, 2019The fill location will be a good clue as to the tank's location. The drain fitting underneath will be the best clue.
Related ContentFuse panel locateFCFS Site locationsOverhead Cab Leak on 2005 Winnie MinnieFresh Water Tank LocationWater pump/filter location
