laknox
Apr 25, 2019Nomad
Yep. Weasel print always says "specs are changeable at any time without notice". Now, even adding the water heater in, you're still 12 gallons, almost 20%, different from the brochure and, I'd argue, that's WAY out of line. You could try raising a stink about it, even to your AG's Consumer Fraud department, but I doubt you'd get anywhere. I think I'd pull the belly cover and put eyes on the tank and see if there's room to add a bigger tank. If your dealer is a stand-up outfit, you could see if they'd work with you on this =and= convince Keystone not to void the warranty if any drilling or welding on the frame needs to be done to support a larger tank.
On re-reading: Keystone is claiming you have a FOURTEEN GALLON water heater?! Really?! I call total b.s. on this! IMO, they simply put in the wrong tank. I think I'd find an identical model and measure the tank.
Even later: OK, so I checked the specs and spec is 12 gal for the water heater, so even the 14 gal heater they claim is bogus, IMO.
Lyle
Lyle
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
