bpounds
Apr 25, 2019Nomad
Rwake901 wrote:
Good idea but will hooking up to the winterize fitting fill the water tank? If I hook up to the normal tank water fill and turn on the water pump will it suck it in from those blue totes ?
I've heard that you can do that. I have a gravity fill port, so I just use that. Sit bottle up on a ladder or similar, use a hose into the fill port. You can also get a small pump that will drop down into the jug and you could send pressure to your fill inlet to assist your onboard pump. BTW, those jugs are threaded 3/4 pipe, so fresh water hoses will connect up, using plastic nipples or whatever. I shopped for the submersible pumps recently, but decided to just use gravity instead.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
