bpounds
Apr 26, 2019Nomad
time2roll wrote:
I would verify the pickup tube extends to the bottom. I would also slightly tilt the trailer toward the pickup tube to get all you can...
Our last trailer was like this. The tank did not have a sump. The outlet was in the side. It was near the bottom, but the result was that when the water level was at about 1.5" it would start sucking air. And 1.5" is a lot of water left, considering most of these tanks are only around 6-8" deep. I modified the pickup so that it would pull down to about the last 3/8" before sucking air.
First think I would do on a new trailer is to cut a flap in the corroplast so that I can lay eyes on the FW tank. Most are translucent so you can see what is what under there. Then measure the dimensions of the tank to verify the actual capacity.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
