lamopar wrote:
Here is a picture of the middle axle and the tank riding on it. You can see the strap and also see how much lower the tank is than the frame rails. I will have to make the cross bracing and vertical supports to hold the tank. Should be easy with some angle iron and all thread and some bracing. I will tack the nuts so they don't come loose.
Wow.
That is just horrible.
Strap with self taping screws holding it.
They should be ashamed of themselves.
My supports have all thread that is attached to the frame and go through the box supports and held on by nuts.
I think there is 3 or 4 supports per tank.
I will have to take a pix.
