DreamComeTrue's avatar
Oct 18, 2022
Waves in the fiberglass - what are they?
I have a 2010 Cougar fifth Wheeler.
It is getting old, I know.
I notice waves (up and down) in the fiberglass here and there.
We just did a big wash on the RV as it gets dirty under trees here on the South Oregon Coast.
I wonder if there is water inside the walls that cause those waves. What else could it be?
I have no leaks that I am aware of, but I do know water between walls can damage flooring etc. My old Alfa slideout floors were destroyed!
We get big storms here on the South Oregon Coast. Have one coming this weekend.
  • It is delamination of the wall. It could be water intrusion which caused damage to the Luann material in the wall. Or it could be that the glue simply let loose. There really is not a repair for the issue. The laminated wall is part of the structural integrity of the trailer.
    If you plan to keep the trailer, the best thing to do is to thoroughly check the roof and all side wall penetrations, such as windows, door, lockers, etc. for leaks. Reseal the trailer and get the leaks stopped.
    Ken
  • enblethen wrote:
    Called e-lamination. Water in wall. Not much you can do to repair damage. Need to seal roof and edges. May slow down process of de-lam,
    Doesn't always mean water in the walls. The front of our FW (under the pin) was like that within 5 years of owning it. We had our repair guy remove it thinking it was de-laminated and yup it was, but not because of water, the cardboard backing came apart. We replaced the entire front part with diamond plate for durability.
  • Called e-lamination. Water in wall. Not much you can do to repair damage. Need to seal roof and edges. May slow down process of de-lam,
