- PlanningExplorerI never wax it.
I use Sea Foam BBG1 Cleaner bug cleaner, then wash it with Meguiars car wash.
After it dries, I coat it liberally with Aerospace 303 and let it air dry. when its mostly dry I wipe it with a 303 dampened microfiber cloth to get the drips. - donn0128Explorer IIAs I read it liquid soap as used in a auto dish washer. Not Dawn which is used for had dish washing
- 2oldmanExplorer II
donn0128 wrote:
You mean dishwasher soap?
Liquid auto dish soap. - donn0128Explorer IIThen your screwed. Using any sort of abrasives on aluminum siding will scratch thru the extremely thin paint layer. Wash and wax just like you would with a car finish.
- dapperdanExplorerI wax the nose of our RV at least 3 or 4 times a season, it makes cleaning the bugs off so much easier. I use NU Finish.
Once a year usually in the fall I go over the entire RV with NU Finish. :B
Dan - Frank55ExplorerThanks for the ideas but I failed to mention that nose is aluminum. Just can't get a good shine on it.
- sojeExplorerlots of people rave about the floor finish products, such as Zep.
Never tried it but concerns about if starting to flake?
Just a thought..............
Several videos on youtube. - 2112Explorer III use 3M marine One Step and then follow up with McGuiar's quick detailer spray in the red bottle
- Mark_HeislerExplorer IIyou need to remove the oxidation first then wax/polish it to get it to shine
look at my profile pictures that's a 11year old fifth wheel and a 15 year old truck
I used ultimate compound and nufinish
There also a new product from 3M its called Perfect-it 36110 gelcoat light cutting polish/wax. Its a one step ( it says you can get it on amazon.com and walmart.com) - donn0128Explorer IIRead a suggestion a few days ago. Liquid auto dish soap. Rub it on and let it sit a while, rinse off. I tried it on the side of my fiver yesterday with one modification. I used a green scotch brite pad and gently rubbed it in. Rinced off off and applied a coat of polish. Beautiful, the oxidation is almost invisible.
I personally like either McGuires RV/Marine in the blue bottles or Colonite boat wax. Both produce excellent shine with moderate effort.
About Fifth Wheel Group
19,027 PostsLatest Activity: Jun 19, 2019
