NC_Hauler
May 14, 2013Explorer
silvercorvette wrote:
Back to the question I posted, I do not recall ever hearing any signs of the truck in regen mode. How can I tell when it is happening, does it make a noise?
There is nothing that tells you that you're in re-gen, you won't "hear" anything, only sign might be the "smell" outside of the truck...the exhaust temps get hotter.....The truck will run a little hotter, (at least it did with the 07.5 Chevy I had as well as the 2010 Dodge I had...."IF" you were to use your information center and had "instant mpg" showing, you would see a drop in mpg until re-gen is done. When I looked at average mpg, I'd see that when I was cruising at 60 mph or so and see the "line" on Average miles per gallon down around 8-9 mpg, I'd know I was in a re-gen.
My 07.5 went through regen, my 2010 Dodge went through re-gen and the 2012 I had went through re-gen...all had DPF (diesel particulate filter). Those that say their truck hasn't went through a re-gen are wrong unless they've deleted that part of the emissions on the truck.
Again, you won't get a message unless your DPF is "full", then you'll be told to run at highway speed for 30-40 mins and it should be ok...I never ever got a message telling me I had a problem with the DPF, and they've been on my trucks since the middle of 07'....BUT, they all have went through re-generations....only way you might know would be to pay attention to aver or instant mpg on information center if you have one in your truck
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
