allcool
Aug 26, 2013Explorer
lincster wrote:
For WD hitches, Hensley is rated at 2000lbs, I belive.
For receivers on the truck, Reese makes the Tow Beast and Pull rite makes one.
The Tow Beast is rated at 2500lbs with a WD hitch.
Thanks for the reply lincster...
Called Hensley, max is 1400tw 14,000 tow
New Reese is 1500tw 15,000tow, but iirr, 1400/14,000 rating with dual cam anti sway.
Equalizer is also 1400/14000. All very nice wd hitches, just maybe not heavy duty enough...
The pull rite does make a 20,000/2000 tw total receiver/hitch type thing that has to be welded or bolted on to the frame. Its not a conventional slide into the receiver hitch. And was told the old 2.5" receiver might need to come off. That isn't an option for me on the lease trucks I get.
I need a hitch that will slide into all the new leased trucks 2.5" oem receiver thats rated for 2000tw 18500 tow.
So what do people do. I can't be the only one that has over 1400 tongue weight...?
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
