Diesel_Camper
Sep 15, 2015Explorer
Is this a fiberglass or metal sided trailer? I know there are some on here that say it is impossible for water to leak through the seams of the interlocking metal siding, but I have seen it with my own eyes. I spent three years trying to track down a leak in my 19' Terry. One day I couldn't take it anymore so I pulled the mirror in the bathroom off and cut a big hole in the wall, pulled out the insulation and saw a steady stream of water coming from the back of one of the seams. If there is dirt/crud in the seam or if it is bowed out a bit due to old staples coming loose you can get a capillary draw that will pull water through those seams. I used some OSI Quad down the length of the seam and no more leak. If I had it to do again I think I'd use some clear Dyanflex 230 because it is much easier to work with and holds up very well. Both are available at home depot.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
