mrw8i
Jun 13, 2018Explorer
I went 5th wheel. I find it easier to tow, no sway issues, even when I'm light in the front (RZR in the back and all the tanks are empty). I also find a 5th harder to backup then a tag, meaning when you have to cut sharp and fit into a tight space - a 5th wheel responds very slow when backing. In a real tight turn you can end up in a pretty awkward position with your tow vehicle. My issues, others with 5th wheels are better at it than I am. A tag will respond immediately to what you want it to do when backing, and you usually need less room to maneuver when backing up and turning into a tight spot.
Good luck. Enjoy the process.
About Fifth Wheel Group
