ACZL wrote:
Buddy of mine recently bought a new GD Reflection(?) BH model and it came w/ West Lake tires. Am not too sure if I read/saw good/bad w/ these tires. I typed in that name into TL search bar and really didn't get anything. Mind you, I didn't google search it either. Are they on same page as other China bomb tires? I told him I'd get back to him. I do not know the size or if ST or LT tires. He did say the sidewall felt a whole lot stiffer on this coach than what he got rid of, so that leads me to believe they are of ST grade. He also said that West Lake makes a heavy duty tire (semis?).
What's the consensus?
I have had Westlake brand tires on the current and a previous trailer, as well as a couple of equipment trailers. As long as Grand Design did not put load range ones on that are borderline overloaded I would run them. Never had a problem with Westlakes and have run them until the tread was worn out.
Now prepared to be bombarded with everything from he needs to run out and buy Goodyear Endurance, or Sailuns or something, to he's going to summon the antichrist by running them.
Fact is those Westlakes are on thousands upon thousands of trailers as OEM tires and have been for years, go to NHTSA and see how many complaints or recalls you find, not many if any. Most owners have never visited an RV forum where it's common that unless you're running what what I'm running, it's often the end of the world.
Westlakes are distributed by Lionshead distributing in Elkhart IN, the same as the wheels they are mounted on most likely, and manufactured by the Hangzhou Zhongce Rubber Co. Ltd, one of the largest tire manufacturers in the world.
