I put the EZ flex/wet bolt/bronze bushing kit on my previous fiver? It saves money to buy a full kit like that and the Ez flex really helped the ride. I also had a couple of bolts that weren't drilled all the way. I put the fiver on stands with the wheels off and a floor jack under the center of the axle to raise or lower as necessary. I did one bushing at a time along with the bushing that was straight across, on the other side. That went really easy and maintained full control of the axle so there wasn't any ohsh!ts while the bolts were out of the spring ends. The bushings also went in and out easily. Craig
Oh yeh, verify this to be sure... Ezflex is the correct kit for one rocker style, probably Dexter, and I think Equalizer is another brand, to replace Lippert rockers. The different brands have different geometry.
