laknox's avatar
laknox
Nomad
Apr 27, 2020
Wet bolt kit recommendation
Looking to put wet bolts on my FW. I know there are several kits available and just looking for recommendations from people who have installed a kit. Specifically, why you chose a particular kit and what, if any, issues you had in installing it. I have Dexter axles and Equa-Flex equalizers. TIA...
Lyle
  • MorRyde, heavy duty shackles wet bolts etc , easy DIY. MorRyde speaks for itself
  • I bought the kit from Dexter, but mine came with the EZ-Flex equalizers. I haven't seen any others except the kit from Lippert that comes with the "no lube necessary" bushings.
    No real issues with installing, I have a triple axle and took my time and did it over the weekend. I did have a reamer to run through the bushing after they were installed to make sure they fit the bolts properly. The worst part was getting everything jacked up to relieve the pressure on the springs.
    Not a very arduous chore at all.
