pcm1959
Aug 29, 2019Explorer II
The wet bolts are supposed to be installed only at a certain angle to help in the addition of grease. They do not rotate in place as they are grooved to prevent them from doing so (at least in the case of the MorRyde wet bolts).
As others have said, simply take a little pressure off each wheel until the grease goes in. You will find the sweet spot and the grease will go in easily.
About Fifth Wheel Group
19,036 PostsLatest Activity: Apr 08, 2026
