Lynnmor
Aug 29, 2019Explorer II
If you use a small bottle jack and place it right at the end of the spring within the hanger, and then jack till it takes grease. You may have to jack till that tire comes off the ground.
What is happening is that the bolt and bushing wears to a perfect mating and the small grease hole would take thousands of pounds per square inch to flow some grease. To head off that problem and get grease to flow to where it is needed, carve a figure eight inside the bushings before installing, you can't make it very deep because the bushings are thin. Here are some examples of what I am talking about.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
