huron52
Mar 09, 2014Explorer
Wet bolts
The bushing that goes around the outside of the bolt and into the ends of the springs. Are they tight that they need to be press fitted into them? The spring ends not the bolts. Thanks
fj12ryder wrote:
Be sure to put a bolt in the bushing when you press them in to help keep from collapsing the bushing. I kept a reamer on hand and had to use it on a couple to keep the bolt from being too tight when the bushings crushed slightly due to a tight fit. Too tight and you may not be able to grease the bushing properly.
