ol_Bombero-JC
May 28, 2017Explorer
paul_arc wrote:laknox wrote:paul_arc wrote:
Hello all, I am looking to change my camping set up and go with a 5th wheel camper which will double tow my flat bed trailer. I am looking for which manufactures and companies have strong frames that could handle a trailer behind it. The trailer is approx 6k lbs loaded, so not too much weight. Tongue weight is pretty minimal.
I am just not too sure what decent manufactures to start doing research on.
I would say frame strength is priority #1.
#2 would be the quality of the trailer its self.
Thanks
Depending on what you get, you'd likely need to reinforce the FW frame all the way to in front of the front axle, to support a 600-800 lb tongue weight. A very few mfrs =might= consider beefing up a frame to handle this kind of weight, but they're very few and far between. Hell, give Space Craft a call and see what a full-on custom would cost. :-)
Lyle
Thanks for the spacecraft name, its good to know a company that can do something custom.
Suggest visiting the SKPs HDT froum. "Serious" trucks (tractors) and "serious" trailers (with serious pin weights), as well as lots of various talented folks, including a hitch mfgr.
Over the years, several HDT owners double towing - although the number has dwindled.
Several "combinations" by folks hauling jeeps on the decks, etc. -
which might be an alternative.
In many states an HDT can be licensed as a Motor Home (No CDL req'd), however CA has put the kabosh on that one - although HDTs already registered as a MH "elsewhere" (apparently) can still be re-registered as same in CA.
Escapees Heavy Duty Truck forum
Another *custom* trailer mfgr (which usually gets more "votes" than Spacecraft) is New Horizons. Big bucks for either one!
:C
About Fifth Wheel Group
