carringb wrote:
Gebrown wrote:
So, with the advice of Scott maybe I should look at trailers weighing in around 4K lbs.
Actually, I wouldn't go much heavier than that, with the truck in its current configuration. Everything modified on the truck decreases its towing ability and payload capacity. You may want to think more along the lines of VRV Living Lite trailer. And even then, the 22-foot model will be pushing your limits if you load it up.
http://www.livinlite.com/axxess8_5x22-overview.php
My first tow vehicle was a lifted F-150 with oversized tires (although nowhere near 35's) and it struggled with my TT at somewhere around 5k lbs. especially in the wind and hills. 3/4 ton much better and still rides high enough and offroads fine for my hunting needs.
