Kafn8td wrote:
I'm at 900lbs HW without the bikes in the rear. I need to weigh it with the bikes in. They total about 900 pounds or so.
Historically speaking, on most TH's with the normal rearward axles placement, tongue weight changes just a little with added bike weights. GVW does change considerably though...
You're now 900lb tongue weight. I assume that is scale weight you measured yourself..?
So now add truck passengers, fuel, wd hitch, baggage, bed cargo, and you are easily over the load capacity of most 1/2 ton PU's 1000 lb tongue max...
jmo
