oztraveler
Dec 10, 2013Explorer
What do we buy?
Looking to purchase a 5th wheel for fulltiming. Towing with a Chevy 2500 Duramax so have to keep within the weight rating whcih is around 15000n lbs. What is the best one to buy?
me1magoo wrote:
By the way, I had a 25' travel trailer with no slides and a F-150. Then I bought an F-250. Then I bought a 28' fifth wheel with one slide. And then a 3500 single wheel truck. Then we had to have the bigger trailer and bought a 35' triple slide rolling house. Yep, it was after several trips and a few uncomfortable moments that I made my 3500 into a dual wheel truck. I won't go back to a single wheel. 2500 or 3500 with or without airbags, single wheels is single tires. I like having the stability and security of the dual wheels on each side.
Yeah, it cost some money to do those upgrades and we started with the first truck and trailer in 2002 and bought the last trailer in 2010. That's eight years and quite a few checks written to learn what we really wanted and then what we needed to tow it safely and comfortably.
Cummins12V98 wrote:
Probably good thing he had a POS hitch. Really who knows how this would have turned out if it had not broken loose. Maybe all would have been fine??????
Veebyes wrote:sidney wrote:
I have seen this accident picture several times before.
I don't disagree that DRWs offer superior stability over SRWs.
But to assume an SRW would have rolled over with the 5th wheel and the hitch (or some other component) would not have failed as it did in the accident is not logical.
What evidence is there that an SWR would have rolled with the trailer?
You would have had to have been there to understand. Lets just say that we were taken within 18" of the edge of the embankment (tires left a mark) before it tore out. Hurricane force sustained gust of wind absolutely broadside on a high profile vehicle is an awful lot of pressure. Had we been a Class B, a C, or even a big A, it is likely we would have been history. When sand & small gravel is traveling horizontally across the road you have alot of wind.
The hitch is rated at 18,000#. Trailer was 13-14,000#.
SRW guys, carry on. Beef them up with airbags etc. all you want. If the day comes when you get hit like we did that DRW extra sideways stability could make the difference between your life or death.
Your call.
