laknox
Apr 24, 2014Nomad
DRM796 wrote:
Was wondering what if anything you put under you landing gear / stabilizers? I used to use a set of blocks that I made out of 4 pieces of 2 x 10 stacked and screwed and glued together. Just recently installed STEADYFAST stabilzers and have not been using anything under the feet. Very pleased with the results of the Steadyfast system.
I just use a couple of my lego levelers for the landing legs, when on dirt, nothing when on pavement or cement. I stack 2x6's for the rear stabilizers, as that's all I've got. FWIW, I've been in a couple campgrounds (and seen rules in others), that =require= you to use boards or pads under all stabilizers. Mostly in hot climates where the sites are asphalt.
Lyle
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
