laknox
Oct 31, 2016Nomad
westom wrote:Jayco-noslide wrote:V-9 engines need extra pistons because they are low performance engines. Even Indy no longer races obsolete technology V-8s. So why are so many RVs still powered by V-8s? Some RV manufacturers fear innovation and change. That explains poor workmanship in other parts of that RV.
I really think that V-8's are pretty much obsolete except for very high performance and race cars.
Cr@p. It's called "reliability". You get more performance, more easily and with less wear and tear, out of a V8; simple as that. When you have to use blowers or turbos to stuff air into an engine, that means extra stresses and, usually, much higher RPM, to make the same numbers. The =main= reason that race engines are only 4 cyl, is to =limit= performance to =limit= speeds. Just like NASCAR uses restrictor plates on the super-speedways. Yes, we =can= get huge numbers from small engines, but I'll put up my 350 hp Genesis Coupe against an older Corvette, with the same output, and that Corvette will simply leave my Genesis in the dust. People forget about torque, which lower-revving V8s have the lock on. Why do you not see pickups with V6s in them to tow anything more than about 8k lbs? Simple, you just need more torque and performance than a V6 can give.
Lyle
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
