I keep reading "stay away from the cheap RV" or "be prepared for more problems with a cheap RV". What do you guys consider a "cheap" RV? Specifically fifth wheels as that is what we are looking at. Is...
Some of the mid - upper range fivers are just heavier built per sq ft, 16 inch on centre framing, even around windows,hung wall const, higher end windows, heavier framing on slide outs, More rigid frames, heavier Gel coat walls vs filon fibreglass finish. For similar use a way more durable over the long range, just my experience.
